Quick Temp question
BLG
Okay so im planning on overclocking but before i do so im debating between two things
either ordering the vantec fan controller and using my mobo stats to keep a check on temp
http://www.newegg.com/app/ViewProductDesc.asp?description=13-999-502&depa=0
Or
Buying something like the areogate II to view temp and controll the fans
http://www.newegg.com/app/ViewProductDesc.asp?description=13-999-154&depa=0
2 main differences that i see, price and temp monitoring, when i over clock my processor i wanna be able to have a constant check my temp, should i spend the extra 30 bucks and buy the areogate II or should i just trust my mobos addon that monitors the cpu and mobo temps
