Hey guys, and gals.
I need a quick suggestion for a Nvidia base video card that has a mini DP. Reason for the mini display port is because I have a Apple Cinema 27 that only has the mini DP.
I have a pretty old Radeon HD68x base card right now that I'm using for this monitor, plus another two 24 Dell monitor. So total of three monitors, and the setup is actually running fanstastic even with 3 monitors, and with such high resolution.
The reason I want to switch to a Nvidia base card is because I'm using a 3D base program called Tekla Structures, and somehow it just run likes crap when I'm modeling. Everything else runs great (including AutoCAD, Photoshop, etc.), but somehow this program is just messed up. I have read that they recommend Nvidia video card, so I am going to give it a try.
My computer hardware is pretty decent (SSD, 8GB RAM, Win 8.1 Pro), so the only other reason I can think of is my video card. Hence the plea for suggestion.
Anyway, I'm pretty open with my budget, but the cheaper the better.
Thanks in advance. And if anyone is particularly familiar with Tekla Structures, please give some advice on what's the best hardware to run the program.
Regards.
Regards.
