Also, nVidia cards in general have some technical limitations beyond the number of pixel shaders that makes them perform poorly in our calculations.
Right now, GPU WUs are set to 660 PPD. As we go through the beta process, we will examine the issue of points for WUs. We do understand the significance of this in compensating donor contributions. We do not expect this will have significant affect on Team scoring.
Approximately how much power will a 4P Xeon E5-4650 rig use from the wall folding under Ubuntu 11.10?
HK is the new Supermicro MP Xeon X9QRi-F+ http://www.supermicro.com/products/motherboard/Xeon/C600/X9QRi-F_.cfm
768w on platinum psus on 220v
This is a large investment for me so I have to be absolutely sure they will work before I pull the ebay trigger.
I was planning to use a 950W PSU from Chieftec .... Or maybe I should go for the 1200W?
Never heard of chieftec
Thank you all, I feel really velcome here I must say.
Is there anyway to check if those ES CPUs will work with the motherboard I mentioned before I might buy them? I do not think I will take a $3400 chance that they will work without knowing for sure.
I have Chieftec PSUs in all my G34 rigs and they ar all working just fine. Chieftec is quite big in Norway and they have a 5 year warranty so I feel safe with this brand.
Mine are C0s on a rather proprietary board...so I cant tell you for sure..but the ones you linked are C1...
24hr power peak is 815w, avg 731w
all time peak 971w .... honestly I would grab the 1050w seasonic...but a 1200w would cause less worry ....keep in mind you have to be able to tap into the whole psu... so check the rails carefully ...
That's the beauty of the AX1200..... ONE enourmous 12V (100A) rail.... so you never have to worry about load balancing. PCIE, EPS12... whatever.... its the same rail. Most other power supplies, you would be right to be concerned about balancing.
