Quick Sansa Clip Question
Hulk
My Sansa Clip stopped working all of a sudden. It will not charge, it will not connect to the PC. It connects but that's about it, I can't open it, it won't charge. I downloaded the firm upgrade but when I try to do these steps:
Q: Should I "Open","Run" or "Save" when i click on "Download Sansa Firmware Updater"?
A: "Open" and "Run" would automatically start installing the software,. "Save" would save it to your computer and you can run it in the future. We suggest you "Open" or "Run" the installer.
Q: How to change to MSC mode:
A: On your Sansa device, press "menu" and go to "Settings" then "USB" choose "MSC"
it won't let me. When I unplug it it dies on my since the battery is left. When it's plugged in it won't let me press any buttons.
What gives???:confused:
Not sure if we are in the similar situation but yesterday mine wouldn't charge.
I just replug the Sansa back into the USB and hit the power button and that seems to jump start it. If not I leave it plug into the USB port for a few minutes and repeat.
Hope that works. Good luck.
