Quick Resolution Question...
danzaman
I am interested in purchasing a 24" Acer Widescreen monitor tom. Black Friday.
The native resolution of the monitor is 1920 x 1200 @ 75Hz and I have an 8800 Ultra Video Card. My card will support this resolution at 75Hz correct? I ran into a problem before with matching a monitor up with a video card and just wanted to confirm. I currently run a 1680x1050 and don't think I remember seeing 1920x1200 as an option in my control panel but assume it will be enabled with I plug it in.
Can anyone confirm this for me?
Thanks,
Dan
CompUSA is selling a 24" Acer Widescreen Digital/Analog monitor for $249.99 - soooooooooooo cheap!
can anyone else confirm this? i'm pretty sure im all set, but i'd like that added security
^^ bump ^^ going out real early tom. and was hoping someone had input on this before I go.
thanks guys
Just so you know: When any LCD is hooked up over DVI its refresh is 60Hz so you don't have to worry about the 75Hz anyways.
Just so you know: When any LCD is hooked up over DVI its refresh is 60Hz ...
Most, but not all.
There are 1680x1050-75Hz LCDs, and 1920x1080-75Hz should be possible over DVI (well, 74.4Hz has been done), but 1920x1200 can't be done over single-link DVI.
