Dan_D said:The only thing that will happen, is that you will get reduced level load times. Though the difference is slight I have always noticed it with my 74GB Raptors.
-(Xyphox)- said:yeah, i love my 150 Raptor, i noticed faster load times in games and OS, even some programs. I have all my programs,software,games,os on it. Accutally thinking of getting another 150 and put them in raid 0
ChingChang said:AFAIK RAID 0 doesn't really help at all in games, and doesn't really affect load times. If there is a difference, it's negligible.
I've never tried it and tested it myself though.
got anything to back this up?Crosshairs said:It does make a difference, and its NOT negligible.....
of course notdrizzt81 said:Can we please stop beating the dead RAID-0 and games horse? Unless someone has some new information (say verifiable benchmarks) on this, I don't think we will change anyone's mind.
Darkatom said:Does having a 150GB Raptor in a gaming rig actually make a difference compared to a 320gb with 16mb cache? Is the difference noticable? For reference my system specs are 6700 (2.6) core 2 duo, 2 gigs of ram and 2 7900GTX.
Rocco123 said:These RAID 0 arguements get started because someone makes a comment as soon as anyone talks about doing a RAID 0, as if the person doing it didn't know what they were doing and didn't know the risks. Yes, there are risks of RAID 0, and moreso than using standalone drives. But we're talking about a .000001 percent change of failure compared to a .00001 percent change.
Brahmzy said:Ya know what? This is EXACTLY why RAID0 gets a bad rap. People spouting BS that have NEVER EVEN TRIED IT!!!!!!!! ARGH!
Anybody who has RAID0 Raptors and plays BF2 KNOWS they will be one of the first if not the first on the map. Period. I've been playing all morning and out of about 8 maps loaded I was the first person on the map about half of those times.
Levels DO load faster...a LOT faster. Good grief people, c'mon!
Well, that's why I rely on benchmarks and reviews to base my statements. If I've never used a high end Athlon64 and I say it will perform better than a high end Pentium 4 in games, would that be BS too?Brahmzy said:Ya know what? This is EXACTLY why RAID0 gets a bad rap. People spouting BS that have NEVER EVEN TRIED IT!!!!!!!! ARGH!
TMan1876 said:The problem is that many, if not most, people that use raid 0 DON'T understand the risks.
As brahmzy said, no important information should every be kept without a backup (whether on a raid 0 array or not).
The chances of a disk failure are waaaaay higher than you think they are.
Rocco123 said:As much as I can argue with all of these statements, wrong thread. I will stop it at that.
OP - Get the 320. Much more bang for the buck.
well, as long as you don't play oblivion, where the single raptor is 30% faster than the Seagate RAID-0 array....Lazn_Work said:http://www.anandtech.com/storage/showdoc.aspx?i=2760&p=10
Yep, two 7200.10 drives in RAID 0 is faster than a single Raptor 150.
In BF2: 1.01 min where a single drive is 1.08, that is 4.2 seconds faster. (quite a bit of time in FPS land)
So if it is worth it to to have twice the cost, twice the power draw, and twice the chance of data loss to have your map load 4.2 seconds faster, go for it.
A Single Raptor takes 1.03 min, so 1.2 seconds slower than the RAID 0 7200.10's.
TMan1876 said:You can argue that important information doesn't need to be backed up?
Rocco123 said:I can argue that we need to remind people to backup EVERYTIME someone so much as mentions RAID 0. I can argue that most people in these forums know that much.
I can argue that I underestimate the chances of HD failures, in standalone or RAID 0 config. I support 1500 servers with more drives than you can count. I'm well aware of the frequency of HD failures, and I know it doesn't happen that frequently.
I can argue that you think most people that use RAID 0 aren't aware of the risks and need to be given 1000 reasons not to use it.
clear enough?
