DangerIsGo
- Apr 16, 2005
I have a 2x120mm radiator (swiftech). Right now, My loop is this CPU-> GPU1 -> Chipset -> GPU2 -> Rad -> pump -> repeat. (tline). My CPU temps are a little above the norm (norm is about 26-27C idle now its 30ish) and GPU1 is a tad above normal, while GPU does always 5-6C over the 1st GPU no matter what. chipset is ok. I was wondering, If throwing in a dual loop with dual rads would help my temps? If not, what about a 3x120mm rad? Or what about a dual loop system? Like loop 1 -> pump -> CPU -> chipset -> rad -> pump while loop 2 is dedicated to GPUs. Would that work? my case is def big enough for both loops but I would need to know if its worth it to. My temps are a little hot and my CPU his prob an all time high of 44C today while encoding and the GPUs went up too even though they arent used. Any other suggestions would be helpful. thanks.
