Quick Questions
L33t Masta
I've watercooled before however I've decided to get back in to the game with my new PC.
I've contacted Danger Den about the availability of their Extended Water Box Plus and such so I'm super excited about that. It comes basically made for watercooling so I don't have to worry about where to mount the radiator, drilling holes for fill ports and ventilation. I'll post my current specs here just in case they're needed to answer any of my questions:
Core i7 920 LGA 1366 (Link)
eVGA nVidia GTX 295 (No Link but self explanatory)
6 x 2 GB DDR3 RAM (Link)
EVGA E758-TR Mobo (Link)
KINGWIN Mach 1 ABT-1000MA1S 1000W PSU (Link)
So my questions are pretty basic since I've been out of the WC game for a while:
1. What is the difference between MC-TDX and MPC-CPU?
2. I'm going to want to watercool my GPU when the new Keplers come out from nVidia. Is the Black Ice GTX 240 radiator that Danger Den suggested for the case going to be enough for some mad overclocks? The case doesn't seem to have enough room for anything more than 1 120mm radiator but I could fit another single 80mm radiator in if need be.
3. Are there any easy to use kits that allow me to tightly and neatly bundle and sleeve my cables in UV reactive green?
4. What are the best cable management techniques I can employ to keep great airflow?
Thanks in advance for any answer :)
Is there a particular reason why you're so set on DD products? They aren't exactly the ground breaking company they used to be.
Not really. I just really like the look of the all acrylic case they offer. Can you suggest something else that you think might look as good and is ready to accept a radiator mount with no additional drilling? And I'm just going with the Black Ice GTX 240 because it was recommended to me. I'm open to suggestions of new parts :)
