I'm ordering my stuff tonight, you've all been very helpful answering to me in the past so everything is good to go my only question is concerning my case, I'm going with acrlyic, is it imperative I get fan holes drilled other than for the radiator for sufficient air flow? If so, how many? I was thinking maybe a 120 in the rear? Again the specs are:
Asus A8R32-MVP
AMD X2 4400+
4 gb OCZ DDR4000
X1900XTX
I will be overclocking at least moderately, so do I need any other fans? a 120 in the rear? the front as well? That's all I need to know and I'm set.
Asus A8R32-MVP
AMD X2 4400+
4 gb OCZ DDR4000
X1900XTX
