Hey guys, just started UD a couple days back and I already joined your team. I have a couple quick questions:
1) Do I need to do anything to have my stats show up at HardFolding.com?
2) How often do my stats get uploaded to the UD website? The client says I have around 1200 points but when I login to my profile at the UD website, it still says zero.
3) I'm using UDTweak to take advantage of my Athlon X2; there is only one instance of the UD client running in my taskbar, but when I check Task Manager, I see two UD processes running and both my cores at at 100% load (which is good). However, since only one instance of the UD client is running, does that thing track the scores for both of the running processes, or just one? Will my results for both processes get uploaded okay?
I was doing BOINC SETI for a while, but that DC project was having too many server issues. I ran F@H for a little while too, but I settled on UD because I like the cause, the interface of the client, and its relatively low memory requirements. I'll add another X2 system as soon as Monarch ships my 4200+ out.
