Quick Question
It's a good thing, the extra slot it takes up allows the graphics card to push some more hot air outside of your case, keeping itself and your other components cooler. Unless you're using all of your PCI slots, it shouldn't be an issue.
Don't, save another $30 and buy the 4770, it only requires a 6pin connector, and its faster then a 4670 and consumes about 20W more during idle/load.
