Quick Question
JKownz
I am trying to find the right screw size and leangth for a Danger Den Black Ice GT Stealth 240 Radiator with the 120MM fans on them of course. Want them to go threw the fan holes and screw onto the radiaor. Anyone know any links or sites where I would be able to buy a few?. any links or info would be much appreciated :)
I have a BIP 240, and if its the same shroud as the stealth, I believe it has M6x32 screws. easiest thing to do is run over to truevalue/ace/home despot with the fan and radiator in your hand and try it out. the screws are about 6 cents apiece, you aint gunna break the bank...
also, check out your reserves of case screws, for hard drives. same size, you might not even need to buy anything.
IT's a screw with the thread 6-32 as tesseracter said. HOWEVER: Don't get a screw ANY LONGER than 1.25" (that's 1 inch and a quarter). Any longer, and you might ruin the radiator.
Home depot sells them in packs of 8 for 1.99$
