Quick question
eddiemc
Description of System:
Zalman HTPC Enclosure HD160
Zalman ZM400B Power Supply
Asus P5WD2 Premium Socket T Intel 955x ATX Main Board
Intel Pentium D 920 Presler 2.8GHz Dual Core CPU
Zalman CNPS9500 LED 92mm Blue Cooling Fan with Heatsink
Seagate Baracuda 7200RPM 300GB SATA Hard Drive
eVGA 256-P2-N555-AX Geforce 7600GT 256MB GDDR3 PCI Express x16 Video Card (factory overclocked)
BenQ 16X DVD -+R with LightScribe DVD Burner
OCZ Gold Series 1GB (2X512) DDR2 SDRAM 667 PC2 5400 Dual Channel RAM
XP Media Center (oem media included)
Hauppauge 1062 PCI WinTV PVR 150 MCE TV Tuner Card
DVICO Fusion HDTV5 Gold Plus HDTV Tuner Card
Remote Control for Media Center
Is this worth $1000???
Seems a bit hight to me. I'd guess if you priced up all those parts on newegg it'd come out to about $900, but then you'd have to build it yourself.
Also that's a horrible CPU choice for a htpc. It'll run hot and need a lot of juice. A lowend Core2Duo or even an X2 3800 would be better imo.
I run a Prescott core P4 3.2ghz oc'd to 3.8ghz in my htpc and it runs just fine, and sold and has done so for the last 18months.
- Josh
