azneinstein
- Feb 25, 2005
Not sure if this is gaming or modding... but here it is:
I have the first gen xbox- which has surprisingly not RROD on me but I sit about 5-6 feet away from xbox, it's sounds like a whirlwind. So being the cheap resourceful self I am, I decided to mod it to be "more quiet"... I have some 120mm quiet fans lying around- and everybody knows 120mm=more air and quieter!
So I go online, great, all the opening tutorials require a special tool... where did I leave that dremel? So I decided to cut a large rectangle on the top of my xbox- and so I want to lay the two fans on top while ductaping the outside of the case and raising the xbox a little to create some channeling. Just seeing if my idea of wiring would suffice in terms of voltage and wiring. I'm trying to avoid soldering anything as I'm lazy and because it's not really "taken apart" I can't really take out the drive.
