Åndhrimnir
- Nov 28, 2009
I'm setting up a RAID array with three 640GB drives. One is completely blank. The second has an un-activated windows install on it which was used only for testing the third drive. The third drive has a windows vista installation on it which I believe is corrupt.
Here's the question: I'm using the same license as is on the third drive to install windows on the new array. If I simply format the drive, will I be able to activate windows on the new array, or do I need to actually uninstall it from the third drive?
