The normal installation procedure is as follows:
1. Insert the SmoothWall Express CD into the CD-ROM drive of a Windows® PC (Internet Explorer
version 5.5 or later is recommended). The Autorun procedure allows you to (a) read the license, (b)
view/print the Installation and Administrator’s Guide in Adobe Acrobat format, (c) create boot floppy
disks, (d) browse the CD or (e) download Adobe Acrobat Reader.
so is smoothwall a standalone operating system or does it run as a application on windows? are there specific hardware requirements? floppy needed?
^ See post #6.
