May 24, 2011 #1 X xbonez Limp Gawd Joined Nov 12, 2010 Messages 274 My reservoir has two pipes connected to it (obviously). One is at a higher level than the other. Which of the two is the pipe that returns the water to the res? The higher or the lower one?
May 24, 2011 #2 A aphasia [H]ard|Gawd Joined Jan 15, 2011 Messages 1,137 are you referring to the swiftech MCRES? i believe the top inlet is the intake and the bottom out. Which of the two is the pipe that returns the water to the res? Click to expand... do you mean 'return water to the pump' right?
May 24, 2011 #3 Tsumi [H]F Junkie 2FA Joined Mar 18, 2010 Messages 14,487 Top one takes in water, the bottom one feeds out water to the pump. Simple as that.
May 25, 2011 #4 86 5.0L Supreme [H]ardness 2FA Joined Nov 13, 2006 Messages 7,131 Aslong as the outlet is below the inlet you should be fine.
