Quick question regarding no signal problem?
bobsaget
Hey guys... I am having trouble with a computer I just put together. It is an 1800+, 9600 Pro and I installed Win XP just fine. I unplugged everything from where I built/installed and relocated the computer to my desk. When I restarted the computer, my LCD monitor isn't picking up a signal. It is displaying the orange colored light that it shows when the computer is not on.
I don't understand what's going on. It works, then it doesn't.
Any help?
reseat everything inside your case, including the memory. Something may have jiggled loose when you were moving it.
See if that fixes the problem
