Quick question on the Soyo 24" LCD.
jordan12
Someone mentioned that they could use this LCD as a tv. Is this possible?
Can I use an HDMI to DVI adapter to connect it to my cable box? Or am I oversimplifying it?
thanks
thanks
Do you know if the cable box requires a display with HDCP? If it does, then it either won't work or will give you reduced quality. Blu-Ray and HD-DVD players require a display with HDCP, and the Soyo doesn't have it. There are very few 24" monitors that don't have HDCP, but the Soyo is one of them. I suggest you research monitors with HDCP if you want to use it as a TV.
Well, I obviously only have the DVI and VGA ports only..
Would like to buy a second soyo and use it as a tv..
Now, with what I have been reading, In HDMI to DVI adapter might work.
But not positive. Could someone sear me in the right direction?
thank you
Err... I just answered you. It will work if your cable box doesn't require a display with HDCP (NOTE: HDCP and HDMI are totally different things. You can have a DVI port that supports HDCP. http://en.wikipedia.org/wiki/HDCP)
Do you want to watch high def tv? Then the Soyo won't work. Standard def only? Soyo is good to go.
