quick question on OCing X2s
option141
OK, so i have a P4 currently, and its a 478, and I only have experience in overclocking this processor.
With the AMD X2s, can I just up the processor speed and not worry about memory?
or do i need to overclock memory as well?
thanks,
seth
You will have to mess with the memory divider if you don't want to overclock the memory.
You will see a decent speed increase if you do choose to overclock the memory as well as the processor though.
ok, so hypothetical situation:
i'm lookin at a 65W 3600+ brisbane AMD X2.
is there a big enough difference betweeen DDR2 667 and DDR2 800 to suggest I should buy DDR2800?
