- Jul 1, 2004
I switched from Nero 6.6 to 7.0 Platinum. In the past, whenever I insert a DVD that I use the "Make Data DVD" option, the old Nero 6 search for my old files, and compares that w/ the hard drive newly updated files, then back up the new files to the DVD.
But w/ ver. 7, it does the entire disc from scratch. How do you tell the damn software to back up just the new files like the way Nero 6 does it?
