quick question on DS3 (about to order)
  • Thread starter Deleted member 21895
  • Start date
965P is what you want
965G has integrated graphics on the northbridge, and I think even when you disable it (use a separate videocard) it still doesn't overclock as well.
IE: the "G" might limit your overclock
You could get the S3 version. From what I've been told it overclocks as well as the DS3. It just doesn't have solid capacitors. I personally would get the Asus P5B-E as it overclocks just as well as the DS3, but has onboard 1394, which is something I need.
