I'm running @ 145FSB on a MB that dosen't lock the AGP/PCI slots, it can run 150FSB, but the chip is locked and can't go that high in raw MHZ, (prime95 fails and quake3 will cause the system to reboot.) the processor I had before this one ran fine at 150 so I know it's not the memmory.
Anyways, knowing that the speeds are out of spec, it it ok to run them at 36.25 and, (if I unlock the Proc) 37.5 for PCI and double those for agp for the long term?
Edit: Also, do I gain anything for running them at those out-of-spec higher speeds? Forgot to ask that.
