quick question..leaving computer on?
robxpark
hey guys. quick question.
is it ok to leave my desktop on all the time or should i turn it off when i go to sleep?
I usually come back from work around 6 and go to sleep around 12 so the computer is only used for those 6 hours or so.
thanks
My computer has been on and folding for over 3 years! It will be OK.
Remember though, your using electricity when its on.
thanks
The only concern this question might really pose for you is your electrical bill, depending on your computer setup/draw. You may save a relevant amount or it may not be an issue at all for you.
