Quick question for TJ07 owners
Scotty_SFF
Nevermind found it out. 140mm Depth, 110mm Width
What's is the size of this hole? Dimensions? Yes i went OTT with the arrows ;)
Looks like i could fit a 120mm fan in there, anyone know if that will work, if not 92 or 80?
i reckon if it's like this (from above)
____________________<motherboard
...............|..............|.....<hole
...............|________|.....<hole
_____________________<edge.
I could drill holes as shown, and tie a fan in...
..............o|..............|o....<hole
................|..............|.....<hole
..............o|________|o....<hole
Yes that's a bad drawing but it will do.
