I just finished my new build and powered it up for the first time. I was elated to see that it booted up without a problem until I noticed that the rear exhaust fan wasn't working. Before I start trouble-shooting on my own, I figured I'd post here and see if it's something obvious. I apologize in advance if I use any terms incorrectly.
The fan is an Antec 120mm Tricool fan with a 3-speed control switch and a 4-pin Molex connector for power (standard on the Antec 900). Instead of stretching a molex connector to the rear though, I used what I think is an adapter that came with a 120mm Scythe Minebea fan I bought for my heatsink. The "adapter" has a male and female 4-pin molex connector and a male and female 3-pin connector. Here's a picture of it:
I connected the fan's molex to one of the connectors on the adapter and connected the 3-pin female connector to an empty CHA_FAN connector on my mobo. Did I use it correctly? If so, is it possible that it's disabled in the BIOS by default (I forgot to check before I powered down and disconnected the fan)? Thanks in advance.
