Quick Question about X58 Motherboards
Seraphic
So these new X58 motherboards have six memory slots in sets of two for a total three sets of two. Does that mean with the X58 you have to have at least one ram sick in each of the three sets for it to work? I mean, should you use two 2GB sticks or three 1GB sticks? Which will work?
You'll get the best performance with running 3 sticks in triple channel mode. However, you can run most boards in single, double, or triple channel mode. Note that some X58 boards only have 4 DIMM slots. On these you can typically run triple channel as well. If you fill all DIMM slots on a 4 slot board, the excess is mapped in single channel mode.
Ummm......there is only 2 sets. The different colors on the slots show you that. So if you want 6GB total, you would put 1 stick in the respective colored slot - 6GB (3x2GB). You would have to get triple channel memory in order for it to work. Looking at prices, they are expensive. Some mobos you can set it up to run in dual channel modes so you dont have to upgrade ur memory if you already have the respective type of memory.
Actually, there are 3 banks on six DIMM slot boards. Each bank has 1 DIMM per channel set. For example, on my P6T6 WS we have:
Channel A2 - White
Channel A1 - Blue
Channel B2 - White
Channel B1 - Blue
Channel C2 - White
Channel C1 - Blue
You can put a DIMM in any slot and the system will detect and use the memory. However, best performance will be achieved when you fill a channel (in this case, the blue slots) with a matched triple set.
Incorrect. Since the memory controller is now integrated into the CPU, every single Core i7 system supports memory in single, dual, and triple-channel mode, meaning that they can operate with any number of memory sticks.
The EVGA X58 allows 1,2 or 3 sticks.....even 4 or 6. Not sure about 5.....:eek:
Most people are going with three channels, either 1 GB or 2 GB sticks.
P6T works with 1, 2, or 3 sticks (only have 3 that I tested, I am pretty sure it will work with 4 and 5 also). You only get fastest performance with 3 DIMMs installed, no more, no less.
