Dec 3, 2004 #1 D DeFex [H]ard|DCer of the Month - June 2011 Joined Feb 13, 2001 Messages 5,248 I was thinking of building something that will use watercooling pumps. what i need to know is, when the pump is turned off does it completely block water flow, block it a bit, or not block it at all. thanks
Dec 3, 2004 #2 R RickyJ Gawd Joined Jun 9, 2004 Messages 1,003 The pump rotor will be a restriction, but usually can still free-wheel.
Dec 3, 2004 #3 S Sideroxylon Gawd Joined Jun 7, 2004 Messages 734 When I drain my system it has to flow through the pump. So, no restrictions here. Should be the same for most pumps.
