Quick question about TRUE installation..
Arklight
Hello all,
I recently recieved my TRUE for my i7 build (it's the new 1366 TRUE with the fan included), and I was wondering which direction the fan is set up to blow by default. It is already attached to the heatsink and I am thinking it would be good to have it blowing air through the heatsink....but.....I am not sure if it is already set up to push or pull. The "Thermalright" logo is facing out (not sure if that makes any difference. There is a cover on the fan so I am not able to see if there are any orientation arrows on the fans "cage" (the fan cover that attaches to the heatsink seems to be on there pretty darn tight!!).
Any help would be appreciated!
The fan is supposed to blow (push) air through the TRUE fin plates, out to the back case fans.
Like Brahmzy said, first fan should be push. Look at the fan blade design and which way it'll push air when spinning.
