andrew1977
- Nov 15, 2006
I'm painting a friends case and was wondering if anyone
has used card stock type paper as a stencil?
My plan is to paint the base coat (white) then apply
the stencils to mask off the areas I want to keep white and
paint over them with red and then mask off some more areas and finally paint it black. Then remove the stencils/masks.
Can't really afford frisket film right now so I thought I'd try using what was available. Anyone tried using cardstock with spray paint and gotten good results or does anyone know of another type of material I should try instead?
