quick question about sli motherboards
drunkenpanda
if my psu doesn't support sli, can i still buy any sli motherboard and just not use the sli function (only 1 vid card)
Short answer is yes....long answer is maybe. It depends on the PSU you using. If you have a nice beefy PSU, then you should be ok. If you trying to run a cheap 400-500w PSU you might run into some problems.
