Quick Question about Q8200/Intel Quads
ClariorHincHonos
Pretty normal to have varying core temps?
56C
44C
38C
42C
Is what I have at idle. Not too worried as it is 17 hours prime stable.
Are you sure something wasn't just loading one core? Automatic-updates or a virus scan?
If not it might mean you mounted your heatsink poorly or applied the thermal paste incorrectly.
run prime95 and watch temps
if they vary from core to core by a lot (>5C) , you should probably reseat your HSF
The temperature sensors on these CPUs were not designed to give accurate core temperatures, especially at idle. Intel only designed these sensors to control thermal throttling and thermal shutdown and pretty much all of them are good at that.
These sensors frequently get stuck. Your first sensor might have that problem. The RealTemp CPU Cool Down Test can give you a better look at how your sensors respond at different loads.
If you're 17 hours Prime stable I wouldn't worry too much about your reported temperatures.
http://www.fileden.com/files/2008/3/3/1794507/RealTempBeta.zip
Varying temperatures are normal even if your sensors aren't stuck. There are a number of reasons why it might be happening, but in the end it all boils down to the fact that it's perfectly normal and you have nothing to worry about.
Cool. That's what I figured. FWIW, cores 1-3 were dead even during prime, core 0 was about 10 degrees higher however. But, like I mentioned its 17 hours, so I think I'll just write it off as an oddball core. Thanks for the input and feedback.
Got this about 3-4 months ago for $100 btw-brand new. :D
