Quick question about Prescotts and IC7-G
eL c0L0mb1aNo
I have to finish a paper and just want to know if the IC7-G (http://www.newegg.com/app/ViewProductDesc.asp?description=13-127-152&depa=0) is compatible with prescott processors. I had to "build" the best mobo/cpu combo under 400 and the IC7-MAX3 was a few dollars too much, so I scaled down the motherboard and upped the processor. THe only thing that has me wary is that the Max3 claims its Prescott ready while the IC7-G doesn't. I'm pretty sure that it shouldn't have a problem with prescotts since they pretty much have the same basic architecture. Thanks for the help guys.
i've seen the is7 (not the is7-e) running prescott, so i assume that all the abit boards CAN run the prescott, just not necessarily very well (i.e. the ai7 - see hardocp's review)
