supremeone
- May 17, 2007
i got a xigmatech hd-1283 and also a LGA775 Bolt-Thru-Kit. But i've never used bolts for this before, i'm wondering do you put the back plate behind the mobo, and than secure it and put it back in the case? Or do you put the backplate behind the rightside panel and attach it that way? If any of you guys know any guides that show pictures, that would be awesome, thanks.
Unfortunately xigmatech doesn't have any instructions for doing bolts, the instructions it had mentioned only pushpin installation, and so far the guides i've searched for having provided the answers i was looking for yet ;o
