quick question about mixing ram...
(cf)Eclipse
Freelance Overclocker
well.. that's registered ecc ram... unless she has a server mobo that requires that type, it's not gonna work :(
what's the rig we're talking about?
Cthulhu
ah... i see. thanks for the reply. yeah, it's just a 2.4b p4 system. :)
E4g1e
Of all the DDR chipsets for a 533MHz FSB Socket 478 P4, only the i875P chipset supports ECC memory. And none of the Socket 478 chipsets support registered memory.
However, it is highly likely that the 2.4B sits on an i845PE chipset-based mobo, in which case you'll have to stick with unbuffered non-ECC memory.
Cthulhu
yeah....no, it's on a abit it7-max2 v2.0...if i remember correctly. it's been over 2 years now since i built it. :D thanks for the info. :)
