Does the card support nvidia turbocache? if so it might make a slight difference. I've never truly educated myself on the turbocache because (no offense) I usually buy high end videocards with insane amounts of dedicated ram.
I believe turbocache uses your system ram for graphics so faster memory may actually help.
If your graphics card doesn't use turbocache then the answer is probably no.
