quick question about manufacturing tech(##nm)
BrandAMDProcessors TypeDesktopSeriesAthlon 64 X2ModelADA5200CSBOXCPU Socket TypeCPU Socket TypeSocket AM2Tech SpecCoreWindsorMulti-CoreDual-CoreNameAthlon 64 X2 5200+Operating Frequency2.6GHzHT2000MHzL1 Cache128KB+128KBL2 Cache2 x 1MBManufacturing Tech90 nm= larger wafer....
BrandAMDProcessors TypeDesktopSeriesAthlon 64 X2ModelADO4000DDBOXCPU Socket TypeCPU Socket TypeSocket AM2Tech SpecCoreBrisbaneMulti-CoreDual-CoreNameAthlon 64 X2 4000+Operating Frequency2.1GHzHT2000MHzL1 Cache128KB+128KBL2 Cache2 x 512KBManufacturing Tech65 nm=smaller wafer
the 65nm chips are actually contructed on a larger wafer... 300mm in diameter instead of 200mm that the 90nm chips are built on... but that doesn't really do much other than allow amd to make more chips at once, dropping the price some
the real difference is that 65nm chips are built with smaller "parts", basically the entire cpu die has been shrunk down.. the benefit of this is reduced power consumption and usually better overclocking.
performance wise, the 90nm may be a weeee smidge faster at the same clock speed, due to some tweaks to the die with the new silicon revision
