I was looking at this page and i was looking at the product with the id #60814. The problem is i need an elbow turn then i saw the one witht the id #60820. From the title i'm guessing the second item is the same as the first but with an elbow built in, am i correct? Also do you think i could get the same effect by just sticking one of those elbow tubes, that you can pick up a dangerden, on to the end of the first item?
thanks
thanks
