quick question about GPH
BlackCat
Hey everyone i recently thought about makeing my own Watercooling system (as to save money and avoid buying one of those ludicrisly priced pre packaged setups) So i just had a quick opinion question...
What would be the best GPH range i would want to look for?
I was thinking somewhere between 170-250 ish gimme some opinions.
i have good luck with a Ehiem s600 which is rated 150gph i also have a via aqua 1300 that is rated 370gph (even though 1300 Lph is 340gph?) and that work well but it doesn't realy have any thing over the ehiem
if you have a restrictive block TDX RBX Whitewater if you need more power to push through the "impingment" but i have a maze 4 and that is very low restriction and that only needs like 50gph to work well.
