Quick question about cpu air flow
Flavorite
errr... which way is the fan mounted on the heatsink suppose to blow? at the cpu or away from? :eek:
In most cases it blows onto the heatsink, but sometimes you get better performance when it is blowing away. (trial and error)
http://tweak3d.net/tweak/airflowtweak/
taken from:
Hardware Specific Tweaks:
AIR FLOW:
H01- http://tweak3d.net/tweak/airflowtweak/
READ THIS. READ IT. it tells how to cure your entire case of hotspots, amazing. "perfect" cooling.
Level of Difficulty: User-Dependant (do you know how to cut your case?) (Easy to Medium)
the first one under Hardware...
EDIT: it's on the 5th page of the article i gave you, so actually read it to find it.
