I probably already know the answer to this, but I just want to make 100% sure before I go blowing something up.
I'm getting ready to shorten and sleeve the cables on my Sugo SG08's power supply and I was trying to think of a way to mark where the wires go in the ATX connector.
Other than the wires that carry a signal and have their own dedicated spot on the connector, can the wires that actually carry current be interchanged within their respective voltages?
I don't have to put each volt and ground wire EXACTLY where it originally went do I? Just as long as I match up the 12v wires with the 12v spots on the connector and do the same with 5v and 3.3v and the ground wires I should be good, right?
The power supply has a single 12v rail if that makes a difference.
