Hello, I recently bought a new Maxtor 200GB drive and want to install Windows XP Pro on it. (HD is in the main system in sig, has BIOS support, don't worry) Now I know that you need SP1 for 48-bit LBA support (>137GB), and of course see that the install only recognizes that much. I'm planning on making a 120GB-ish partition on there to install Windows then once I install SP2 make another partition. Will this plan be okay? What about if I resize the 120GB partition with PartitionMagic later? That OK too?
