KillerTomato
- Nov 29, 2004
me and my dad both have a comp using xp pro. they both have the same key. is this bad? there both registerd.
thats strange as heck, usually MS blocks the 2nd one until you call them. Hey, I'll be nice and wont tell themKillerTomato said:ya there both activated
First, don't say "M$." It just makes you look dumb.KillerTomato said:whats wierd is that i did call M$ and they said "you have to buy a new product key" then they said "oh your copy is OEM, you dont quilify". I did give them my xp service code and stuff. wow how did this work!?
EmbraceThePenguin said:Well, They will both work fine, however, you might not be able to update the software on them. That would be bad considering its M$... Opps... MS
Actually, even that doesn't work legally. OEM is for new computers only, you'd either have to overhaul one system (new mobo) or get Retail.RS3RS said:...If you used the same installation on two computers, the only way to get legal again is to remove it from the second computer, and order an OEM copy of XP from some place like newegg. As long as you use it on two computers, no how the activation process went, it's still illegal.
