The Phenom II's are decent folders, but they're not Core i7s. Still, if you get a decent Phenom II and overclock it (I guess since this'll be an HTPC that's going to be quite unlikely, though...) then it should put out quite a bit of ppd.
oh it'll still get OC'd as i'm not anal about noise, i'll try and get a good low profile cooler for it eventually.
and i know it won't hold a candle to my i7
and if i end up buying new, it'll be the Athlon II X4 620. but hopefully i can find something better used
The 620 has now been replaced by the 630 and 635 but you may still find one, howver they are nt the easiest cpu's to over clock and the retail heatsink is useless. Your best bet would be to look for a PII used - try and get a C3 stepping chip as they run cooler
Another thing to consider would be an X6 if they are released soon
i was just going off newegg, but thx i'll look for 630's. And yea, ive been trolling the FS section here looking for good dealsand i'm trying to keep this below $500
and if i'm going dual core, i'm not spending 120 on a CPU lol, so thats why i'm not going intel for this![]()
I also think that a Phenom II X6 would be a good idea for folding. You can use the exact same components you would use with a Athlon II X4 630 but you can get the two extra cores which should give it about the same performance as an i7 920 at the same clock speed for A3's. Places in Canada already have the 1055T (2.8GHz,125W) priced at $215CAN and the 1035T (2.6GHz,95W) should be cheaper (maybe $175US?). 3.5Ghz with reasonable temps should be possible and then you could get 10K ppd.
what kind of ppd could I expect from a quad core AMD cpu running the a3 client?
