quick pelt question
um sure...? if you dont know what condensation is you need to use the search function before buying the stuff unless you want to learn the hard way (sometimes thats the best way ;) ) its only 'nonsense' as you say. it also depends on your hardware. when trying to cram everything into a small case theres usualy a balance between space and performance.
