Quick pc case advice
Im going to build a SUPER cheap computer. My goal is to build an entire working compute for under $150 just to see if it can be done. I'm basically aiming to build a internet and office machine that would be relatively responsive to the person using it etc.
I plan on installing freebsd with one of those ASrock motherboards and a 1.8 ghz athlon/duron etc.
after its built i will most likely use it as a simple server to host my screenshots and stuff.
But basically, do any of you think the psu on thisthing will explode on me after too long ?
thanks
The power supply might explode and possibly kill other components, but with your pricerange you cant get much better.
Might melt..that looks like a pretty cheap case (Just kidding! Not really). I suggest extra fans and a blow hole.
thanks
My suggestion is :
Buy one of those cheap cases from EBUYER that are ~15 shipped.
And buy a GOOD psu..
such as this one
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-444&depa=0
Enermax Noisetaker 370W for $54 shipped on newegg.com
I'm sure you can find something just as good, for less.
Some people here like fortron's, others think sparkle's are good. I disagree with them, and I buy ONLY enermax, antec, or PCP&C powersupplies [enermax being my daily purchase]
I'm sure someone will say that THIS http://www.newegg.com/app/ViewProductDesc.asp?description=17-104-988&depa=0 FORTRON for $25.99 shipped is quite good.. I'd say no, but, that's cause I just don't believe you can get a good PSU for $20
If you want to go on the cheap...
http://www.newegg.com/app/ViewProductDesc.asp?description=11-145-034&depa=1
This case features a 400W psu for $32.49 SHIPPED.. I'm sure it's no WORSE than that $53 shipped, 350W system you are looking at..
Laforge said:
My suggestion is :
such as this one
so buy a cheap ass case and get a really good powersupply seperate ? I need an entire casing solution psu + enclosure for like $40 this machine has to be ungodly cheap. Let me see if i can work this out.
