Jan 21, 2009 #1 B BassKozz Limp Gawd Joined Nov 10, 2005 Messages 311 Quick Question: Which is faster a 2.4Ghz P4 or a 2.8Ghz Celeron?
Jan 21, 2009 #4 R rflcptr Supreme [H]ardness Joined Mar 27, 2008 Messages 7,063 Do you know if it's the 'C' revision? If so, you also have Hyperthreading as an advantage.
Jan 23, 2009 #5 B BassKozz Limp Gawd Joined Nov 10, 2005 Messages 311 Thanks for your help rflcptr, I am buying a used computer from a local college, and I have a choice between a: Compaq Evo D51s or Compaq Presario SR1010NX The Evo I believe is a 2.4Ghz P4 , while the Presario is a 2.7Ghz Celeron. So I assume the Evo would be the better machine to go for? I plan on putting Ubuntu linux on it. Thanks, -BassKozz
Jan 23, 2009 #6 P PC_User Supreme [H]ardness Joined Sep 15, 2007 Messages 5,022 Pentium. I've been staying away from Celerons for most of my life.
Jan 23, 2009 #7 R rflcptr Supreme [H]ardness Joined Mar 27, 2008 Messages 7,063 I'd recommend at least 1GB RAM for everyday use, as well.
Jan 24, 2009 #8 comp24seven Limp Gawd Joined Sep 22, 2005 Messages 424 P4 for sure !!! the S478 Celerons ( even Celeron D) - s***s
Jan 24, 2009 #9 B BinarySynapse [H]F Junkie 2FA Joined Feb 6, 2006 Messages 13,984 comp24seven said: P4 for sure !!! the S478 Celerons ( even Celeron D) - s***s Click to expand... The Celeron D's were suprisingly good for what they were in their day. Of course the new Core based Celeron's stomp them into the mud.
Jan 24, 2009 #10 C cpusmoking n00b Joined Dec 10, 2004 Messages 15 P4, Celerons are good for Grandmothers only JK
Jan 24, 2009 #11 bigdogchris Fully [H] Joined Feb 19, 2008 Messages 19,116 The 400mhz bus Celerons suck absolute balls.
Jan 24, 2009 #12 Mr. Bluntman Supreme [H]ardness 2FA Joined Jun 25, 2007 Messages 7,268 I typically avoid Semprons or Celerons like the plague. Get a P4.
Jan 24, 2009 #13 L lostnkonfused Limp Gawd Joined Feb 23, 2008 Messages 133 The P4 has more cache than the celeron--get the P4.
Jan 27, 2009 #14 B BassKozz Limp Gawd Joined Nov 10, 2005 Messages 311 Thanks for all the feedback everyone, P4 it is
