quick overclock question
Hulk
I just did a fresh reinstall of Win 7 and I would like to know if I use the motherboard CD to install the drivers if my overclock will stay or will I have to input settings again to overclock the CPU all over again. My i5 4670k is overclocked to 4.1Ghz.
if you overclocked using the BIOS, there should not be any issues when you install the drivers. I would suggest just installing the network drivers if you need them then pulling down the latest drivers from the motherboard website.
