chowchewchee
- Jul 31, 2005
it's me again
my question is this do athlon 64's perform better with higher bandwidth and looser timings or higher clockspeeds and tighter timings?
the reason i ask is i have figured out that my 4400 can handle 270x9, ram 1:1 2.5-3-3-10 2T resulting in 2430mhz cpu and 540mhz RAM (not bad for ddr400). however, i can also run it at 253x10, ram 1:1 2.5-3-3-7 2T for a total of 2530mhz cpu and 506mhz for the ram. am i better off going with solution one or solution two? does the extra 100mhz and the slightly tighter timing for solution two make it better than the 100mhz slower but more bandwidthy solution one?
helf!
helf!
