Quick OCing question regarding FSB and dividers
ty1er
When OCing, is it better to have the FSB running at certant specific frequencies. Lets say when OCing the FSB to 333mhz, does that allow other components to run at stock speeds?
Obviously, when bumping up the FSB on a motherboard it inturn OC's everything related to the FSB - RAM, Chipsets, HDs, etc. What I'm asking is, is there certant frequencies, maybe 333, or 400mhz that dividers kick in, and are used that allow everything in the system besides the CPU to run at stock specs.
I see alot of people who have OC'ed systems run the FSB at 333 and 400, I was just wondering if this was the reason.
Thanks!
I OC the CPU and leave everything else alone.
I unlink the memory bus and then OC alone if I feel the urge.
I leave the other settings on auto.
It avoids confusion if the OC crashes.
333 is used a lot with E6600 to achieve 3ghz. (9 X 333mhz), or to match the speed of DDR2 667mhz.
And 400mhz to fully utilize the RAM speed when using DDR2 800mhz which is probably the most common.
The HD does not get overclocked and anything in the PCI / PCI-E, AGP slots doesn't get overclocked either since those areas can be manually locked while overclocking.
Overclocking the RAM is a choice since buying DDR2 800mhz allows for a 400mhz FSB and most people will stay below that. Then there is faster RAM such as DDR2 1000mhz or so.
That leaves you with your CPU and the motherboard (chipset)
Ah, that makes sense. I forgot about the PCI / PCI-E, AGP Locks.
Thanks for the info!
